It is currently Wed Aug 13, 2025 2:16 am
 Post subject: Bridge weight and size
PostPosted: Sun Nov 29, 2015 6:18 am
Hi
Just wondering what weight most people aim for with a bridge design.
I have bought a couple of rosewood ones from china and was going to use them as a starting template
Will be trying to make one out of ebony for an om model, the worry is how heavy it will be and how that effects the responsiveness
Heres a pic to help Image
PostPosted: Sun Nov 29, 2015 7:37 am
You people think and worry too much.
Glue it on and play it.
These users thanked the author Haans for the post (total 2): cablepuller1 (Sun Nov 29, 2015 11:12 am) • jack (Sun Nov 29, 2015 10:50 am)
PostPosted: Sun Nov 29, 2015 9:48 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I weigh all my bridges regardless of species and make them 30 grams. The heavier the bridge, the lower the fundamental resonance of the top. A lower fundamental adds warmth but too much can sound muddy and detracts from the high end. I weigh mine as part of the tuning process I use to get consistent results.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: cablepuller1 (Sun Nov 29, 2015 11:11 am)
PostPosted: Sun Nov 29, 2015 9:54 am
First name: Tom
Last Name: West
State: Nova Scotia
Cable:
I use a rectangular shape around 1"by 6" and the weights are generally in the mid 20 grams.
Tom
These users thanked the author Tom West for the post: cablepuller1 (Sun Nov 29, 2015 11:11 am)
PostPosted: Sun Nov 29, 2015 11:48 am
Martin Ebony belly bridges weigh about 35 grams
Ken Cierp
These users thanked the author kencierp for the post: cablepuller1 (Sun Nov 29, 2015 12:02 pm)
PostPosted: Sun Nov 29, 2015 2:15 pm
There's no single 'right' answer to this, as the posts so far show. The best weight for the bridge in a given case will depend on what you're making and what you want it to sound like.
The function of the bridge is to tie the strings to the top, and tell them how long they are so they'll know what note to make. It has to be strong enough as a tie-down so that it doesn't break, and stays glued on. It's mass and stiffness serve to define the string length, along with the mass and stiffness of the top. Secondarily, the bridge is the heaviest brace on the top, and one of the stiffest, so it alters the way the top works. You work with these variables to get what you want.
In theory, a string only works right if it's ends are fixed to something that's totally immobile. The problem is that top that doesn't move would not make any sound, so we're automatically violating that condition. Fortunately, there's a range of values of motion for the top that will work well enough to avoid problems. The heavier and stiffer the bridge is, in general, the less motion you'll get for a given top stiffness and weight. On a top that's flexible in the center, such as a scalloped braced Dread, you will probably need a stiffer or heavier bridge to keep from running into 'wolf' note troubles. That ebony bridge of Martin's that weighs 35 grams does the trick there, especially if you add in some more weight for the pins and saddle. On a smaller top that used 'tapered' bracing, which is stiffer in the center, you'd need less mass, and a lighter bridge would do.
Adding mass in the bridge tends, all else equal, to cut down on the power the guitar can produce, but it cuts it down a lot more in the higher frequencies. Putting on a heavier bridge doesn't give more sound in the bass than t a light one does; it gives less. But, by cutting down the treble even more it produces a 'bassier' sound. Sometimes a small difference there can have a big effect. One of my students once got a little carried away in carving her bridge down, and ended up with one that weighed about 20 grams. The resulting sound was too 'bright' for her taste, and we ended up adding a couple of grams by sticking some poster adhesive inside the top as a quick expedient. Later, when we had time to put on more than a simple wash of shellac, the sound improved, and we were able to remove the goo.
Stiffness with low weight has the opposite effect; it cuts bass more than treble. A light bridge will tend to be more 'responsive' than a heavier one.
There is something of a trade-off between power and sustain too. Adding either mass or stiffness with all else equal will tend to reduce the power of the guitar a bit by restricting top motion, but should add sustain by keeping the energy in the strings longer.
For my own steel string guitars, with 'tapered' bracing, I tend to look for the bridge weight to end up around 25 grams, or maybe a bit more. You can fine tune the weight of the system some by using different pins. Plastic ones weigh about 3 grams/set, ebony is about 5, bone closer to 8, and so on. In some cases, as with my student's guitar, a couple of grams can really make a difference.
These users thanked the author Alan Carruth for the post (total 5): TimAllen (Tue Dec 01, 2015 12:50 am) • MikeWaz (Mon Nov 30, 2015 3:07 am) • Greg Maxwell (Sun Nov 29, 2015 7:56 pm) • jack (Sun Nov 29, 2015 7:22 pm) • cablepuller1 (Sun Nov 29, 2015 3:48 pm)
PostPosted: Sun Nov 29, 2015 3:50 pm
Thanks Alan ..great info in there... will try to keep it light as i now know i can add weight if needed with ebony pins
PostPosted: Sun Nov 29, 2015 6:00 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Here are a couple old threads on this topic you might find interesting. The first one has quite a few specific numbers for bridge weights from various folks.
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43096&hilit=bridge+weight
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=45491&hilit=bridge+weight
These users thanked the author J De Rocher for the post: cablepuller1 (Mon Nov 30, 2015 5:20 pm)
PostPosted: Sat Dec 05, 2015 9:07 am
Years ago I had a test guitar that came out of the chute sounding amazing, it had an ebony bridge that weighed approx 35 grams, I decided to test the lighter bridge theory, the lighter I went the worse the guitar sounded....I ended up putting a heavier bridge back on and the beautiful sound returned. I have found that lighter bridges don't work for me, go figure. FWIW.... I build/brace pretty light as well.
Gwaltney Guitars
These users thanked the author GregG for the post (total 2): cablepuller1 (Sat Dec 05, 2015 12:53 pm) • jack (Sat Dec 05, 2015 10:33 am)
PostPosted: Sat Dec 05, 2015 10:37 am
Last Name: Kincheloe
Scalloped or tapered bracing?
PostPosted: Sat Dec 05, 2015 12:23 pm
Tapered
Gwaltney Guitars
PostPosted: Sat Dec 05, 2015 12:56 pm
GregG wrote:
Tapered
Huh, I was betting on scalloped since it lets the bridge move more independently, whereas tapered keeps the whole soundboard tied together so it should have plenty of effective mass... unless perhaps if it was a small guitar, especially with a cedar top since that can get extremely lightweight. Or maybe some resonance issue that only shows up when the total power is increased? I need to read the Gore/Gilet book more thoroughly on that topic...
Users browsing this forum: meddlingfool and 28 guests
